Hi
Just got a shipment of routers through a reseller, I’m working with several members , they said they are getting boot failures when attaching R5SHPn , this is one of them
RouterBOOT booter 2.29
RouterBoard 433AH
CPU frequency: 680 MHz
Memory size: 128 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
insmod: cannot insert /lib/modules/2.6.27.39/misc/flash.ko': Invalid parameters (2): Invalid argument failed to open /dev/flash: No such device insmod: cannot insert /lib/modules/2.6.27.39/misc/flash.ko’: Success (2): Success
modprobe: failed to load module flash
Starting services…
Demo license expired!
Please reinstall the router.
Segmentation fault
connect failed (errno=2)
Shutting down…
Stopping services…
System halted.
Fixed by upgrading to 5.14 using net install and updating booter
My question is .. is this gonna repeat itself? “Demo License” ?? I’m afraid that when installed in a remote location and it fails on me
