BootLoop after Update
I updated a Mikrotik CRS328-24P-4S+RM to the latest Stable-Version labeled “7.14.1 (stable) 2024-03-08 12:50:23”
Since the Update, the Device is in a permanent Boot-Loop…
Since then, I tried
Loading the backup RouterBOOT loader…
Resetting the RouterOS configuration…
Starting the RouterBOARD in Netinstall mode…
All failed to recover, does somebody have an Idea how to fix?
P.S:
I understand, that the 16MB Storage Size is most likely the Issue.
But at the Time of the Update, there were no Warning / Information in the Changelogs of the Issue.
Just want to Fix my Switch :laughing:
Has anyone found a fix for this? I’m in the same situation
Mikrotik offers free support for this kind of issues.
A few hours later, a range of console error messages including “not an elf header” from the failed upgrade, and I’ve now managed to use netinstall not only to recover the switch but to install a fresh 7.14.1 onto it without any further issues.
For anyone else that comes across this, I ended up doing a full storage format using console in the process, but am not sure if this was a necessary step.
Quick Feedback regarding my BootLoop-Issue
After a few failed attempt, I was also able to use Netinstall to recover the Switch with the latest 7.14.2(Stable)
Everything works normally again!
