both-address and ports in PCC Load Balance
Dear I´m new by here! Well, I am implementing a Load Balance with PCC, and wondered if the “bug” in both-address and ports at the 3.27 version (Per Conection Classifier) was corrected in 3.30? Because this was not before loading youtube, it was necessary to press the regarregamento browser. Any News?
Regards
there is no bug - if you use “both-addresses-and-ports” you will get such problems for sure. you need to use “both-addresses”
Thanks! But, for my experience, the both-addresses adjust does not add the links, it just makes balancing! In my case I have tree links of 10 mbits, when I use a profile of dwonalods of 12Mbits in my hotspot I can not reach that speed because the links band are not added. Is there any other way to solve this problem?
I hope you can help me.
Regards
the only way of summarizing your channels is bonding. and you need to be able to terminate it on the other side
