I have VRRP setup on two routers, an RB1000 (primary) and an RB450G (secondary) both running 4.6. The primary has a priority of 254 and the secondary 100. The IP addresses are setup correctly and traffic passes on the primary. When I bring the secondary online, it switches to master after a few seconds and then both nodes are master. I’m guessing the secondary isn’t getting the advertisements from the primary and assumes it’s the only node. Has anyone else had similar issues or success with VRRP on 4.6?
Primary:
# mar/20/2010 10:28:03 by RouterOS 4.6
# software id = LLDD-T1RN
/interface vrrp
add arp=enabled authentication=ah comment="" disabled=no interface=bonding1 \
interval=1 mtu=1500 name=vrrp1 on-backup="" on-master="" password=\
password preemption-mode=no priority=254 vrid=1
Secondary:
# mar/20/2010 17:24:55 by RouterOS 4.6
# software id = B86B-NECF
/interface vrrp
add arp=enabled authentication=ah comment="" disabled=yes interface=bonding1 \
password preemption-mode=no priority=100 vrid=1
