hi there!
we have small problem with wireless link, listed in the subject. both routers 2,4GHz, 256MB, SR5. Every day routers rebooted with no reason. One router, after that - other router. No log entries both sides.
Any suggestions?
Kind regards,
C. G.
Check current and voltage. If those two are not OK board will reset when burdened. Or maybe you have some scripts that reboot your boards daily or on some other condition…
all voltages etc. are perfect.
regards,
C. G.
and /system/scripts contains nothing
