bottleneck in CHR HELP !!
I am presenting a problem, I am installing a new CHR and doing laboratory tests I present the following problem when generating traffic.
The results are the following:
UDP
Send 4.0 to 5.0 Gbps (Maximum)
Receive: 9.0 to 9.8 Gbsps
TCP
Send 9.0 to 9.8 Gbps
Receive: 4.0 to 5.0 Gbps
as they will realize the limitation that is generated is reversed.
Currently the Server is a PowerEdge R640 with intel x710 nic, and we are using 10Gb SFP + DAC cables.
SO Hyper-V
It has P-unlimited trial licenses
And our interfaces are in:
Autonegotiation: Incompleted
Rate: Unknown.
The SMT is disabled.
What can be the cause of this?
I hope I can count on your help, best regards.
did you solve this?
if yes, how did you
