bought a license for 3.13 for a pc
hi,
I just bought a license for 3.13 for a pc. i have a powerstation radio and i want to use the pc to act as a router inorder to allow for different users with different login name and password and to have a web login page. that is why i bought the mikrotik license. i need help on how to configure it.
you can see wiki.mikrotik.com
try to search wireless
i have looked at it. but what i need is a configuration that can enable the powerstation radio to get internet access from the pc acting as a router such that when user login they first see a webpage login page and i can assign more than 200 users.
thanks.
if you have a mikrotik router, you don’t need the powerstation anymore. seriously
make a simple hotspot with the routerOS server and connect the powerstation as station router, to make NAT of the 200 computers..
hi Ibersystems,
good point, please can you give a configuration on how to makr the hotspot router server and make a NAT of the 200 computers. I have already configured the powerstation as as access point (ap) but i can login to change is as a station.
please send me the configuration so that i will configure the hotspot router server and NAT for the 200 computers.
Thanks.
HI,
I have no time today to make you the configuration : P
You could search in the wiki.mikrotik.com to make a hotspot. Later use powerstation as station and NAT.
Good Luck!
watch this for example http://www.tiktube.com/index.php?video=53
rtfm
thanks everyone i have got.
I searched this expression in google.. xD
basically you did what the acronym asked you to do :slight_smile: even if it was meant for the OP
i did as Ibersystems suggested, i set up the router server and set the powerstation as a station instead of as an access point, but i no longer see the powerstation among my wirelss signals. but when i set it as access point i see it.
what do i do?
and again on my pc that is serving as a router server, i have three lan ports. how do i connect to the PoE of the powerstation radio?
Put the RouterOS as AP-BRIDGE… and the powerstation as station..
but i am using my pc as a router and i dont see on winbox where to set it as Ap-bridge
what command do i use to set it as AP-Bridge.
and i have 3 ethernet card (lan card) how do i set each as either ether1 or ether 2 so that i can connect one to the internet modem and one to the PoE of the powerstation that will be set as a station.
Please help.
thanks.
LOL,
then configure the PC as a hotspot and the powerstation in bridge mode…
I suposed that the PC has wireless : P
But I think that 200 users are to many users for this..
Good luck!
please what do you mean by LOL
i have configure the pc as a hotspot and the powerstation in bridge mode.
i dont understand this statement: I suposed that the PC has wireless : P
i can reduce the 200 users to 100
