I am using BR951G-2HnD for mobile devices. Just try to see what is maximum that I can achieve.
In any option my max Down/UP speed is 17-18Mbps.
Just to try in compare I used TL-WR741ND one of the cheapest router on market.
On the same/default configuration 30/20 is my results.
I have try:
disable chain1 on RX/TX
Set to : indoor
set only 20Mhz, 20/40 both
Set only N and only G (only G is catastrophe no more then 5)
etc.
I will post my default configuration which I used before any changes.
And one again I have use that device only for mobile phone (lumia 620 tested on tp-link) nothing tragic but annoying.
what is your laptop client card ?
Or just only one client Lumia phone.
There is no Laptop, just my phone lumia.
You could try to monitor TX power. for best performance it should be around -40 -50dB
In terminal /in wire registration-table pr
Try to install latest 6.34.2 Version end enable wireless-cm2 package.
I will try defiantly but now is Friday evening and is time for family
I will continue in Monday and post results with “enable wireless-cm2 package”
We are using RB devices a lot from rb750, CRS, till CCR but almost newer for Wi-Fi.
Just trying to see, if can I get results for simple 2.4GHz, indoor usage, just as other vendors on market.
Ok, now is Monday and I am trying again to achieve ~Tp-link wifi 2.4 performance.
I have enabled wireless-cm2 package the result is the same.
On the last try I have opened my BR951G-2HnD and attach external antenna X2 on board connectors.
The signal is little bit better but the performance is the same.
My Lumia 730 as client
INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL-STRENGTH TX-RATE UPTIME
0 wlan1 14:9A:10:xx:xx:xx no -41dBm@1Mbps 54Mbps 16m17s
Is there some user who achieve "normal" speed on 2.4 on same or similar device?
Most likely interference or some other factor at play. Are you running on the same channels, same frequency width, etc? No issues with RB951G here, 90/40 mbps from my phone on 2.4GHz / 802.11n
The problem is that at connection of Lumia to other router (to TpLink, Zyxel, ZTE) the speed of transfer makes 50-70mbps, and at connection to a Mikrotik speed 10-12mbps
the same problem.
I have try:
tp-link 740n (factory and openwrt firmware)
tp-link 741nd (factory and openwrt firmware)
tp-link 842ND (factory and openwrt firmware)
Linksys wrt300n
airport extreme
Linksys WRT54GL (openwrt)
all router done great or normal, apple exceptional, maybe the greatest home router I have ever tested but price >300EUR is also exceptional
No Way to push mikrotik to work greater then 12-15 Mbps on my nokia lumia 730 and all my testing started because clients complain to me that his BR951G-2HnD doing the same performance as I in my company in testing lab.
The client is not cranky because they are using mobile just for news and messengers. Speed is not crucial but annoying problem persist.
