Hi all,
I have recently acquired an LtAP LTe6 Kit.
I have managed to do a basic setup wherein I have installed the SIM card and have managed to get internet working over the wireless network.
I need to set it up with a second SIM from a different carrier to allow for failover and hopefully load balancing as well.
I’m very new to this, and it’s taken me a while to get this far.
My devices that I will be using will be plugged into a switch coming from the ethernet port on the LTAP. Once it is all set up, I will probably disable the wifi as it will be used in a scenario where wifi is not needed.
Does anyone have a super basic tutorial or some step by step instructions to help me get this set up? I’m comfortable using the terminal instead of the gui if that helps.
Thanks!
