Branding / .dpk files - is it possible to "unpack" one to see the contents?
Wasn’t sure if this belonged in General or the scripting/API section (since it’s related to “branding” and automated setup). Feel free to move it!
I have inherited someone else’s setup using netinstall and then GenieACS/TR-069 to provision and then manage devices. There are TR-069 commands to update ROS on devices (hAP AX2&3) along with a .dpk / “branding” package, and then reboot the device.
Is there any way I can “extract” the branding package / dpk file on a computer to see what it does, or so I can make a new version of it? Or do I need to have the original source files that generated the dpk in order to make a new one?
Npk's are squashfs images that can be decompressed with 7zip.
No idea if branding is the same, but worth a try...
Awesome, I tried running it through file and it just told me it was “data,” I wouldn’t have thought it was something 7z could handle. :smiley:
WARNINGS:
There are data after the end of archive
Path = [redacted].dpk
Type = SquashFS
WARNINGS:
Offset = 65536
Physical Size = 24576
Tail Size = 81
Headers Size = 4596
File System = SquashFS 4.0
Method = XZ
Cluster Size = 262144
Big-endian = -
Created = 2025-06-05 11:59:40
Characteristics = DUPLICATES_REMOVED EXPORTABLE NO_XATTRS
Code Page = UTF-8
Everything is Ok
Archives with Warnings: 1
Warnings: 1
Folders: 14
Files: 19
Compressed: 90193
I’m a little concerned about the warning, but I’m seeing files that make sense to me, so i’m way better off than before. Thanks!
They are signed by Mikrotik, and the additional data is that signature.
binwalk is also a great way to analyze and extract random data blobs.
You can ask binwalk to extract everything it can find in a blob like so:
binwalk -eM branding-file.dpk
