What do I have to do to get access to branding maker?
Best regards
Best regards
by login at the main website.
Smart answer, but the question was for Normis, because Branding maker is not enabled on my account…
branding packages are available only to distributors
but i need to quit that, i need the defaults values, how can i disable the branding packages.
Regards
only by reinstalling RouterOS
i re install ros using netinstall on rb751 but not reset to default.
Make sure that you have not requested it to retain any configuration information.
