Hi, I am using a passive QSFP+ to 4x SFP+ breakout-cable:
https://www.fs.com/de/products/303321.html?attribute=9518&id=4048434
I have bond QSFP+1 and 2 and QSFP+3 and 4 (XOR-bonds).
My problem is, if I restart the switch or the remote devices, sometimes the bonds shows as "up" and the member-interfaces too. But 1 member interface does not not receive or transmit any traffic.
Because everythings stays "up", this situation gives you totally random effects, some connections work, some drop (I assume based on the Transmit-Hash of the bond and if the working or "dead" interface is used).
What helps, disable the affected interface, which shows "0 bps" for a longer time and re-enable it.
Interfaces are configured with "10G base CR", no Auto-Neg, FEC to Auto. Two DAC-cables are affected and it is not always the same member-interface.
