I have:
auto-upgrade: yes
boot-device: nand-if-fail-then-ethernet
cpu-frequency: 720MHz
boot-protocol: bootp
force-backup-booter: no
silent-boot: yes
protected-routerboot: enabled
reformat-hold-button: 2m17s
reformat-hold-button-max: 2m32s
- Before formatting - everything worked
- After formatting - nothing works, the first and last LEDs are on.
Winbox and Netinstall does not see either when connected via a switch or directly to the port. The reset button was pressed for 15, 20, 120, 130, 140, 150 seconds.
What else can be done?
