Today i tried to upgrade my new RB433, i choose combined package for rb 400 series but after reboot RB doesn’t stand up
RouterBOOT booter 2.14
RouterBoard 433
CPU frequency: 300 MHz
Memory size: 64 MB
Press any key within 2 seconds to enter setup..
loading kernel from nand... OK
setting up elf image... OK
jumping to kernel code
netinstall doesn’t see hardware on serial console
when I tried to send firmware file via serial Xmodem I have only message “invalid upgrade file id”
Please help
I fix it. RB433 doesn’t work with 3.7 mipsbe package. I install back 3.6 and it works again
I have the same problem with RB433 and MT 3.7.
MikroTik 3.6
MikroTik Login:
Rebooting…
Stopping services…
installed system-3.7
Restarting system.
RouterBoard 433
Memory size: 64 MB
loading kernel from nand… OK
setting up elf image… OK
and … NOTHING !!!
The only solution was installing MT3.6 from Netinstall.
I guess they figured it out…
What’s new in 3.9:
*) bridge could make router busy even without traffic;
*) fixed route redistribution in RIP (bug introduced in 3.
*) fixed AR5212 kernel crash on setting change;
What’s new in 3.8:
*) fix B mode rate reporting for Atheros 5211 cards;
*) IPv4-compatible addresses as IPv6 route gateways now require
manually specified interface;
*) fixed removing external routes from OSPF;
*) added initial version of layer-2 mesh routing protocol;
*) fixed problem - OVPN server sometimes crashed;
*) fixed problem - torch could fail to aggregate connection data;
*) fixed problem - RB500 on high ethernet load rebooted sometimes;
*) fixed problem - if PPP (ISDN) client requested it’s own address, then server
did not report it in logs correctly;
*) fixed problem - if PPP (ISDN) client has it’s own address, it was
not used allways as on-demand ip address;
*) fixed problem - PPPoE, PPTP & L2TP stops receiving packets, if
MRRU is set and multiple packets get lost;
*) added support for Intel Gigabit PCI-Express cards;
*) fixed problem - RB433 did not work with v3.7;
And I remember some “smart guy” said that RouterOS was not board specific…hmmm…not the RB433. That sounds pretty specific.
ADD: I trust the opinions of those who buy these boards over the opinions of those who sell them. Nothing personal…
RouterOS is an operating system. RouterBOARD is a hardware device. There are drivers in Operating Systems that make the Hardware work. If the driver has a problem, the hardware will not work correctly.
I hope it’s not news for you
Not news to me, normis. That was my arguement with the smart guy. Can’t remember who. The OS is not “board specific” as in you don’t need a special version for each board. But still possible to have bugs with only one board due to hardware differences.
