You should use the latest netinstall program and install the latest RouterOS version. Set the RouterBOOT to etherboot (to use netinstall) and connect it directly to your PC network card.
And xmodem can only upgrade the RouterBOOT, not RouterOS.
I have both the latest version of netinstall and the routeros software…
It is well understood routeros itself cannot be upgraded from serial…
I have the connection between the routerboard and pc connected through a decent enough switch but ill do a direct connection to see if that helps anybit…
could you post the print out from your console when you boot the board up, so we could see what bios version are you using?
What happened when you specified to boot form Ethernet, could you post the printout form the console?
Code: 02001021 00002821 26440ad4 <94820000> 24c60001 00c7182b 00a22826 1460
fffb 24840002
ctl_zap
W: stay in same state 0
Atheros-5212 0000:00:04.0: uevent: unsupported action-string; this will be ignor
ed in a future kernel version<3>pci 0000:00:03.0: uevent: unsupported action-str
ing; this will be ignored in a future kernel version<3>pci 0000:00:02.0: uevent:
unsupported action-string; this will be ignored in a future kernel version<3>pc
i 0000:00:00.0: uevent: unsupported action-string; this will be ignored in a fut
ure kernel version<3>serial8250 serial8250: uevent: unsupported action-string; t
his will be ignored in a future kernel version<3>platform flash-nor: uevent: uns
upported action-string; this will be ignored in a future kernel version<3>platfo
rm rb500-cf: uevent: unsupported action-string; this will be ignored in a future
kernel version<5>SCSI subsystem initialized
libata version 2.21 loaded.
RB500 CF
scsi0 : cf-rb500
ata1: PATA max PIO6 cmd 0xb8a10800 ctl 0xb8a1080e bmdma 0x00000000 irq 149
korina korina: uevent: unsupported action-string; this will be ignored in a futu
re kernel version<3>rb500-nand rb500-nand: uevent: unsupported action-string; th
trying bootp protocol…
OK
Got IP address: 192.168.1.109
resolved mac address 00:11:2F:7E:C1:9F
transfer started … transfer ok, time=1.68s
setting up elf image… OK
jumping to kernel code
Welcome to MikroTik Router Software remote installation
Press Ctrl-Alt-Delete to abort
so it means the netinstall is working. In the Netinstall specify the latest RouterOS packages to install. And after installation specify the router to boot from the NAND.
No offense to any, but I think If I do another netinstall imma loose my sanity. I think im just stuck with a board that went dead on me, no bigge; its all a part of the wisp game, losses that is. I guess ill just turn this board into the tftp server ive needed for so long but refused to dedicate a standalone box to it.
