bridge 3 vlan on diffrent interfaces
hello everyone
my provider give me sip trunk service with a vlan .i have two voip server and i want to connect them to provider vlan. i make two vlan for each servers.for example vlan 10 for server one on ether 1 and vlan 20 for server 2 on ether 2 .when i bridge one vlan with vlan provider it works correctly but when add second vlan that belong to other voip server,it disconnect from network.
Good Evening,
Are you sure the “Sip trunk” Provider accepts multiple Servers connected at once?
A know a lot of Providers that don’t allow this at all.
And if they allow it, they usually want more money!
If that’s not the Problem, maybe it’s the Mikrotik-Config.
If you post the config of the Mikrotik device. we can check it
(/export hide-sensitive file=anynameyouwish)
