Dear Professionals
I’m having problems with making IPsec tunnel between two offices. I asked a question the other day about IP. Now, I’ve found that I can bridge the ADSL modem to my RB450G in order to get rid of the IP that My Modem gives to the router.
So, I can easily put my Zyxel or Maxnet Modem on Bridge mode. What I don’t understand is how to set up the RB450G to be able to dial the PPPoE connection.
This is what I did so far:
1.Created a ppp profile with change TCP MSS= yes
2.Created a PPPoE Client with my username and password from my ISP and assigned the aforementioned profile to it.
3. I went to the IP addresses and deleted the IP that was given to router by the modem.
4. IP Firewall NAT and masqueraded the pppoe interface
At this point I can see my public IP in addresses and I can connect to the internet, however I can no more connect to my modem and I’m afraid that someting is wrong and my security is at exposure.
Here’s my detailed options:
PPPoE Client
admin@MikroTik] /interface pppoe-client> print
0 R name="pppoe-out1" max-mtu=1480 max-mru=1480 mrru=disabled
interface=ether1-gateway user="xxxxxxx" password="yyyyyyyyyy"
profile=ppp-wan service-name="" ac-name="" add-default-route=yes
dial-on-demand=no use-peer-dns=yes allow=pap,chap,mschap1,mschap2
[admin@MikroTik] > ip firewall nat print
0 ;;; default configuration
chain=srcnat action=masquerade out-interface=ether1-gateway
1 ;;; default configuration
chain=srcnat action=masquerade out-interface=pppoe-out1
[admin@MikroTik] > ip address print
# ADDRESS NETWORK INTERFACE
192.168.88.1/24 192.168.88.0 ether2-master-local
1 X 192.168.1.3/24 192.168.1.0 ether1-gateway -------> Disabled this
2 D x.x.x.x/32 x.x.x.x pppoe-out1
