Bridge and HotSpot - Job At Stack
Can anybody help me out?
I am running version 2.8.11, I have a bridge (IP = 10.0.0.1 for Admin purpose) which contains three NIC; ether1 connects to the Internet, while ether2 connects to a switch where other nodes are connected.
The Microtik box was actually designed to be a bandwidth manager, but now I want to implement a wired HotSpot on ether3 which worked fined but nodes on ether2 cant access the internet since HotSpot is using tcp port 80.
How can I change the HotSpot tcp port?
Thank You
Yummy
You can change the port in IP->Services.
Yeah, thanks! But when running the HotSpot setup, I am forced to use another port for www services since it appears port 80 is default for HotSpot. Hence after changing port in IP->Services I still have to do some changes manual in Firewall but after doing this I could get the login screen and logon but cant browse the Internet from the HotSPot client
you can change it at firewall by youself by hand,remember to change all of hotspot’80 port in firewall config.
try it .
my english is poor,so may writer is not right,by the mean is true.
:laughing: Thanks Pals, I finally got the HotSpot to work and it does so beautifully. The only problem now is how can I exclude some systems from been authenticated?
Thank you
YomiCiouz
