bridge between two interface
I would like at the same addressing connect the port 2 of 10.
In this configuration does not work Internet.
what I did wrong?
My settings
[admin@MikroTik] > interface print
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU
 0  R  ether1                              ether            1500  1598       9498
 1  RS ether2                              ether            1500  1598       9498
 2  RS ether3                              ether            1500  1598       9498
 3  RS ether4                              ether            1500  1598       9498
 4  RS ether5                              ether            1500  1598       9498
 5     ether6                              ether            1500  1598       9498
 6     ether7                              ether            1500  1598       9498
 7     ether8                              ether            1500  1598       9498
 8     ether9                              ether            1500  1598       9498
 9   S ether10                             ether            1500  1598       9498
10     ether11                             ether            1500  1600       9500
11     ether12                             ether            1500  1600       9116
12     ether13                             ether            1500  1600       9116
13  R  bridge1                             bridge           1500  1598
[admin@MikroTik] > interface bridge print
 0  R name="bridge1" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled
      mac-address=4C:5E:0C:3F:31:35 protocol-mode=rstp priority=0x8000
      auto-mac=yes admin-mac=00:00:00:00:00:00 max-message-age=20s
      forward-delay=15s transmit-hold-count=6 ageing-time=5m
[admin@MikroTik] > interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
 #    INTERFACE               BRIDGE               PRIORITY  PATH-COST    HORIZON
 0    ether2                  bridge1                  0x80         10       none
 1 I  ether10                 bridge1                  0x80         10       none
[admin@MikroTik] > ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   xx.xx.xx.xx/30     xx.xx.xx.xx     ether1
 1   10.0.4.1/23        10.0.4.0        ether2
[admin@MikroTik] > ip firewall nat print
 0    chain=srcnat action=masquerade log=no log-prefix=""
[admin@MikroTik] > ip dhcp-server print
 #   NAME                                                               INTERFACE                                                              RELAY           ADDRESS-POOL                                                              LEASE-TIME ADD-ARP
 0   dhcp1                                                              bridge1        ip-pool        1w3d       yes
[admin@MikroTik] > ip pool print
 # NAME        RANGES
 0 ip-pool        10.0.4.10-10.0.4.24
        10.0.5.3-10.0.5.121
