Bridge between Wifi and LAN + HW for that
Hi
I have a small knowledge about Mikrotik devices so maybe someone could point me in proper direction :wink:
I need to do a bridge between Wifi interface and Ethernet (LAN) interfaces - wifi side will be connected to other AP
From my small knowledge it should be fairy easy to do on MT - connect to AP, create a bridge and attach wifi and ethernet
interfaces to the bridge - if I’m wrong please correct me.
What I need is a hardware with 2 ethernet ports and - of course - wifi 2.4ghz
I don’t need anything fancy or something from the top shelf :wink: - I found this - https://mikrotik.com/product/RBmAP2nD -
it has wifi and exactly 2 ethernet ports - just as I need :slight_smile:
Will this be sufficient for my requirements ? (to connect to AP and create a bridge)
Yes you can use the mAP2nD for that
  1. make a bridge
  2. put all 3 ports in the bridge
Thanks a lot for confirmation nickshore :smiley:
