Good evening, Colleagues! There is such a scheme
Two switches are included in the router like bounding(802ad). United in the bridge. In bridge 4 vlans
and working perfect. But if I add ether(on router) to bridge PC don’t work. Paid I added.
Post the configuration following the guidelines in my automatic signature below, the crystal ball is broken. It is too easy to mess up a bond configuration.
Bounding ether1,ether2 - > ESW1
ether3,ether4 → ESW2
/interface bonding print
0 R name="bond0" mtu=1500 mac-address=0C:D5:71:14:98:00 arp=enabled arp-timeout=auto slaves=ether1,ether2 mode=802.3ad primary=none
link-monitoring=mii arp-interval=100ms arp-ip-targets="" mii-interval=100ms down-delay=0ms up-delay=0ms lacp-rate=30secs
transmit-hash-policy=layer-2-and-3 min-links=0
1 R name="bond1" mtu=1500 mac-address=0C:D5:71:14:98:02 arp=enabled arp-timeout=auto slaves=ether3,ether4 mode=802.3ad primary=none
transmit-hash-policy=layer-2 min-links=0
Vlan interfaces
0 R name="ISP" mtu=1490 l2mtu=1496 mac-address=0C:D5:71:14:98:04 arp=enabled arp-timeout=auto loop-protect=default
loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=9 interface=bridge-core
use-service-tag=no
1 R name="MGMT" mtu=1490 l2mtu=1496 mac-address=0C:D5:71:14:98:04 arp=enabled arp-timeout=auto loop-protect=default
loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=10 interface=bridge-core
use-service-tag=no
2 R name="User-A" mtu=1490 l2mtu=1496 mac-address=0C:D5:71:14:98:04 arp=enabled arp-timeout=auto loop-protect=default
loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=11 interface=bridge-core
use-service-tag=no
3 R name="User-B" mtu=1490 l2mtu=1496 mac-address=0C:D5:71:14:98:04 arp=enabled arp-timeout=auto loop-protect=default
loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=12 interface=bridge-core
use-service-tag=no
Bridge configuration
0 R name="bridge-core" mtu=auto actual-mtu=1500 l2mtu=1500 arp=enabled arp-timeout=auto mac-address=0C:D5:71:14:98:04
protocol-mode=rstp fast-forward=no igmp-snooping=no priority=0x8000 auto-mac=yes max-message-age=20s forward-delay=15s
transmit-hold-count=6 ageing-time=5m region-name="" region-revision=0 max-hops=20 vlan-filtering=no pvid=1
Bridge ports
0 interface=bond1 bridge=bridge-core priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
external-fdb=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-all
ingress-filtering=no
1 interface=ether5 bridge=bridge-core priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
external-fdb=auto horizon=none hw=yes auto-isolate=no restricted-role=no restricted-tcn=no pvid=11 frame-types=admit-all
2 interface=bond0 bridge=bridge-core priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto
Bridge Vlans
0 bridge=bridge-core vlan-ids=9 tagged=bond0 untagged="" current-tagged="" current-untagged=""
1 bridge=bridge-core vlan-ids=10 tagged=bond0,bond1 untagged="" current-tagged="" current-untagged=""
2 bridge=bridge-core vlan-ids=11 tagged=bond0,bond1 untagged=ether5 current-tagged="" current-untagged=""
3 bridge=bridge-core vlan-ids=12 tagged=bond0,bond1 untagged="" current-tagged="" current-untagged=""
ether 5 don’t work
OK, але я трошки не зрозумів, що насправді не працює. When you say, in the first post, “But if I add ether(on router) to bridge PC don’t work.”, do you have in mind that if you connect the PC 5 to ether 5, only that PC doesn’t work, or that all PCs (including those connected via switches) stop working?
If only the PC connected to ether5 cannot get anywhere, the explanation which is not obvious at first glance from the manual is that if you want the local /interface vlan to be able to talk to external devices via the bridge, you must put the bridge itself to the tagged list under /interface bridge vlan:
/interface bridge vlan set [find vlan-ids=11] tagged=bridge-core,bond0,bond1
Plus vlan-filtering on bridge-core must of course be set to yes but I assume you have that already.
And please translate “Paid I added” from the first post back to Ukrainian or Russian, I couldn’t guess what you had in mind. Плату я додав via google translate is my best guess…
