- RouterOS 7.1 beta2 all work. RouterOS 7.1 beta3 and up, including rc3 have problem;
- RB750Gr3;
- Using the configuration below for RouterOS 7.1 beta2 version. Bridge for wan interface and interface for IPTV is working correctly. IPTV receives all the necessary packages, updates and shows everything without problems.
When using routeros 7.1 version higher than beta3, for example rc3, IPTV does not receive some of the packets and cannot start.; -
[mmmmm@Rrrrrr] > /export hide-sensitive
sep/14/2021 00:01:00 by RouterOS 7.1beta2
software id = NVNU-MDCM
model = RB750Gr3
serial number = CC210B0F****
add admin-mac=C4:0B:CB:FF:AA:AA auto-mac=no name=bridge-beeline
add name=bridge-lan protocol-mode=none
set [ find default-name=ether1 ] mac-address=C4:0B:CB:FF:AA:AA name=ether1-ext
set [ find default-name=ether3 ] name=ether3-comp
set [ find default-name=ether5 ] name=ether5-iptv
/interface wireguard
add listen-port=51820 mtu=1420 name=wg
add name=local
add name=ISP
/ip hotspot profile
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool0 disabled=no interface=bridge-lan lease-time=3d name=dhcp1
/ip vrf
add list=all name=main
/certificate settings
set crl-download=yes crl-use=yes
add bridge=bridge-lan interface=ether2
add bridge=bridge-lan interface=ether3-comp
add bridge=bridge-lan interface=ether4
add bridge=bridge-beeline interface=ether5-iptv
add bridge=bridge-beeline interface=ether1-ext
/interface bridge settings
set use-ip-firewall=yes
set discover-interface-list=local
add interface=bridge-lan list=local
add interface=bridge-beeline list=ISP
add interface=ether1-ext list=ISP
/interface wireguard peers
add allowed-address=0.0.0.0/0 interface=wg persistent-keepalive=10 public-key="XI6hPp1j2RFtrd8kojbfec0HFeCQnIyhXqdGoYxxXCQ="
add address=192.168.1.1/24 interface=bridge-lan network=192.168.1.0
add address=192.168.2.1/24 interface=wg network=192.168.2.0
/ip arp
add address=192.168.1.242 interface=bridge-lan mac-address=50:EC:50:0A:01:AA
add address=192.168.1.16 interface=bridge-lan mac-address=24:4B:FE:8B:AA:F2
add address=192.168.1.15 interface=bridge-lan mac-address=DC:B7:2E:AA:AA:92
/ip cloud
set ddns-enabled=yes ddns-update-interval=1h
/ip dhcp-client
add disabled=no interface=bridge-beeline
/ip dhcp-server config
set store-leases-disk=immediately
/ip dhcp-server lease
add address=192.168.1.242 mac-address=50:EC:50:0A:01:AA server=dhcp1
add address=192.168.1.210 client-id=1:c4:34:aa:aa:ef:b mac-address=C4:34:AA:AA:EF:0B server=dhcp1
add address=192.168.1.91 mac-address=DC:A6:AA:AA:96:69 server=dhcp1
add address=192.168.1.16 client-id=1:24:4b:fe:8b:aa:f2 mac-address=24:4B:FE:8B:AA:F2 server=dhcp1
add address=192.168.1.15 client-id=1:dc:b7:2e:56:a6:92 mac-address=DC:B7:2E:AA:AA:92 server=dhcp1
add address=192.168.1.0/24 dns-server=1.1.1.1,8.8.8.8 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,8.8.8.8
add action=add-src-to-address-list address-list="Honeypot Hacker" address-list-timeout=4w2d chain=input comment="block honeypot ssh rdp winbox" connection-state=
new dst-port=22,23,3389,8291 in-interface=bridge-beeline protocol=tcp
add action=add-src-to-address-list address-list="Honeypot Hacker" address-list-timeout=4w2d chain=input comment="block honeypot asterisk" connection-state=new
dst-port=5060,20561 in-interface=bridge-beeline protocol=udp
add action=masquerade chain=srcnat comment="nat for internet" out-interface=bridge-beeline
add action=dst-nat chain=dstnat comment=nextcloud dst-port=80 in-interface=bridge-beeline protocol=tcp to-addresses=192.168.1.16 to-ports=80
add action=dst-nat chain=dstnat dst-port=443 in-interface=bridge-beeline protocol=tcp to-addresses=192.168.1.16 to-ports=443
add action=dst-nat chain=dstnat comment=ubuntu dst-port=2221 in-interface=bridge-beeline protocol=tcp to-addresses=192.168.1.16 to-ports=22
/ip firewall raw
add action=drop chain=prerouting in-interface=bridge-beeline src-address-list="Honeypot Hacker"
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/ip hotspot service-port
/ip service
set telnet address=192.168.1.0/24 disabled=yes
set www disabled=yes
set ssh disabled=yes port=2200
set api disabled=yes
set winbox address=192.168.1.0/24,192.168.2.0/24
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=bridge-lan type=internal
add interface=bridge-beeline type=external
/system clock
set time-zone-name=Europe/Moscow
/system clock manual
set time-zone=+03:00
/system identity
set name=Rrrrrr
/system logging
set 1 action=disk
set 2 action=disk
set 3 action=disk
/system ntp client
set enabled=yes
/system ntp client servers
add address=88.147.254.230
add address=88.147.254.235
/system package update
set channel=development
/system routerboard settings
set auto-upgrade=yes
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=local
/tool mac-server mac-winbox
/tool sniffer
set file-limit=5000KiB filter-interface=ether5-iptv filter-stream=yes memory-limit=1000KiB streaming-enabled=yes streaming-server=192.168.1.16
5. The attachment contains an archive with two files. This is a packets sniffer dump via wireshark. The settings of tool packets sniffer are visible in the configuration above.
File # 1 RouterOS 7.1 rc3, where IPTV is not receiving the required packets.
File # 2 RouterOS 7.1 beta2, where everything works without problems.
[WireShark.zip|attachment](upload://4555QEJXAr7yj2P04GLhk3kVCo9.zip) (399 KB)
