bridge filter to drop brodcast
helloooo
anyone can help me???
i have a problem in my network i need to stop the broadcast
the ip firewall not working on the bridge mode
im using
/interface bridge filter
add action=accept chain=forward disabled=yes mac-protocol=pppoe-discovery
add action=drop chain=forward disabled=yes
need to add a chain input
accept winbox 10.10.10.1,10.10.10.2,10.10.10.3,10.10.10.254
accept icmp
accept MNDP
input drop ALL
thank you :slight_smile:
Hi haissam,
If on your network you only use pppoe, than your bridge rules are all you need (except that they need to be enabled :slight_smile:). But do this kind of filter on every bridge you have unless the pppoe-server.
Another more generic rule would be one to do “port-isolation” with bridge ports. E.g.
add action=drop chain=forward in-interface=!UPLINK out-interface=!UPLINK
Any input rule won’t interfere on broadcast.
