Hi All,
I’m looking for some help with a test setup,
I’ve setup caps man 1 devices is the Managers and 1 device is acting as the AP.
The traffic is being bridged locally on the AP.
I’ve 2 different SSID’s each one is tagged into different vlans. which generally flow out ether1 as tagged.
I planned on using a bridge filter rule to keep some mDNS local and stop it being forwarded out ether1.
However I’ve got an issue
When I create a bridge filter rule I had planned on matching by destination mac address and protocol udp 5353,
however to use the protocol & port option I need to set the mac protocol to 800(IP) however packet capture on the bridge
shows the ethertype to be 0x8100 since it’s vlan tagged.
I am wondering is there a way to us bridge filtering selectively like this while still using vlan tags.
Any suggestions are appreciated
I’m guessing that it can’t be done
that’s unfortunate,
