Dear,
i’m using the bridge filters for some purpose, but with ros 4.x they work perfectly , otherwise with ros 5.x they dont work if the connection tracking is disabled,
but the contrack is more expensive for cpu and i loose tcp t-put with it.
is possible to do enything ?
