Bridge filters
I would like to filter out certain IP blocks/ports/protocols, at the clients end, to make sure none there crap gets on to our network. The problem is that the AP-Clients are all bridged not routed so non of the firewall rules will work, I have tried a few other things with filters under the bridge section but have not found a way to do it.
What is the best way to accomplish this task, and can someone point me in the right direction.
Erik
in bridge settins, check ‘Use IP Firewall’ =)
Thanks :smiley:
Next time I’m in Minsk I buy you a beer!
I knew it had to be something simple!
Erik
catch you in a word! =)
Is bridge filters worikng in v5 betas?
I am trying in beta1 at beta4 without not moving in the counters… only now in the gateway i can get the counters moving but only in chain INPUT, have a lot of RBs bridged with filters not counting…
