Bridge Firewall and Wireless lan controllers
I have had this issue for sometime. This happens with Ruckus and Entrasys WLCs. My router is used as a hotspot when I have my bridge settings use ip firewall checked my aps will not be adopted into the controllers. I have disabled all fw rules during testing and the only way it works is to uncheck use ip firewall which is not an option. My current workaround is to have everything plug into a headend switch and then my mikrotik. Has anyone else had this issue and resolved it? Im sure its some firewall rule or hotspot rule that just eludes me.
Maybe a diagram with your network topology and your configuration export with hide-sensitive parameter would help to understand better what the issue might be…
