I have been experimenting with the new vlan bridge filtering in the hope that it may solve an issue I have been having with peering. I am talking to a remote host that presents to me with the same MAC over two physical interfaces. Each physical interface has a separate vlan tag on it and of course different L3 addresses.
I have a CRS317 switch between my router and the two interfaces - my intention is to bridge the two interfaces and allow the vlans to both be presented onto a single interface on my router. The issue seems to be that the despite the hosts table in the bridge being able to handle multiple lines with the same MAC and different vlan, they must have the same physical interface. In other word the bridge router is unable to lookup which interface to send the packet down based on the MAC and the VLAN tag, but instead can only use the MAC.
I have recreated the much simpler situation in the lab and have recreated the fault. Here in the configuration:-
My Router - ether1 connected across to ether1 on the “switch”
/interface vlan
add interface=ether1 name=vlan20 vlan-id=20
add interface=ether1 name=vlan30 vlan-id=30
add address=192.168.20.1/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.1/24 interface=vlan30 network=192.168.30.0
The “switch” (actually another router) ether2 and ether3 carry vlans 20 and 30 and are plugged into ether2 and ether3 respectively on the far end router.
add name=bridge-main vlan-filtering=yes
add bridge=bridge-main interface=ether1
add bridge=bridge-main interface=ether2
add bridge=bridge-main interface=ether3
/interface bridge vlan
add bridge=bridge-main tagged=ether1,ether2 vlan-ids=20
add bridge=bridge-main tagged=ether1,ether3 vlan-ids=30
The far end router (which I don’t control). Given it presents with a single MAC over both interfaces I assume this must be the MAC address of a bridge.
add admin-mac=02:CA:6D:3F:62:F1 auto-mac=no name=bridge-peering \
vlan-filtering=yes
add bridge=bridge-peering interface=ether2 pvid=40
add bridge=bridge-peering interface=ether3 pvid=50
add bridge=bridge-peering tagged=ether2,bridge-peering vlan-ids=20
add bridge=bridge-peering tagged=ether3,bridge-peering vlan-ids=30
/interface vlan
add interface=bridge-peering name=vlan20 vlan-id=20
add interface=bridge-peering name=vlan30 vlan-id=30
add address=192.168.20.2/24 interface=vlan20 network=192.168.20.0
add address=192.168.30.2/24 interface=vlan30 network=192.168.30.0
N.B. under /interface bridge port I set the pvid to be 40 and 50 so there was no chance of conflict - we are not interested in any untagged traffic
From the first router I am able to ping 192.168.20.2 but not 192.168.30.2
Only a single entry appears in the “switch” host table:-
# MAC-ADDRESS VID ON-INTERFACE BRIDGE AGE
7 D 02:CA:6D:3F:62:F1 20 ether2 bridge-main 1s
I am able to ping 192.168.30.2 only by disabling ether2, relaxing the vlan filtering and allowing the traffic to all go over ether3. Then I get the same mac address on vlan 30, but they now both are on ether3.
5 D 02:CA:6D:3F:62:F1 20 ether3 bridge-main 0s
9 D 02:CA:6D:3F:62:F1 30 ether3 bridge-main 7s
If I am asking too much of the vlan filtering, can anyone suggest another way to do this? I can’t change the far end of course. I would also like to continue to use the hw acceleration features of the CRS317 (so I can’t put bridges on top of vlans). I would also like to avoid pulling the physical interfaces back to the router (don’t have enough sfp+).
