Bridge from WAN/internet AP to RB751-b lan
I am trying to bridge from our main internet providing AP to a mikrotik rb 751-b for some lan devices.
The problem is that the broadband/WAN address range is being assigned to my pc connected to ether1, instead of the AP DHCP range as I expected. Internet does not work.
My setup and configuration currently:
TL-WR1043ND router connected to WAN (PPPOE) address range 196.xx.xx.xx. The router is configured as an AP with DCHP of 192.168.1.0/24 (100 - 200). All our devices connect fine and receive IPs and have internet access.
Mikrotik RB752-b with firmware 2.37. I set up the wlan1 to connect to the AP in station-pseudobridge mode. It connects fine.
I put ether1 and wlan1 in bridge1.
My pc is connected to ether1.
This did not work as my pc got a WAN range ip and internet did not work.
I tried adding a DHCP Client on bridge1 but this didnt work either.
I put a static ip of 192.168.1.150 on bridge1 one, still no luck.
I took a look at http://forum.mikrotik.com/t/ether-wireless-and-bridge-routed-question/83742/2 but I can’t figure out if this is 100% applicable to what I am trying to do and also not sure what to change to make use of this information.
I would appreciate any pointers.
This should have worked and your computer should have gotten an IP in the range given out by the AP you connected to.
I just defaulted an RB951ui-2Hnd, removed the default settings then bridged ether1 and wlan1, set the wireless to Station-Pseudobridge, connected wlan1 to a local AP with internet and set the bridge as a DHCP Client. I rebooted the router, my PC got an IP from the AP that I connected to and I was online.
The RB751 does not have port 1 in the switch chip like the RB951. I don’t know if this would make a difference but if it does you might try using ether2 instead. I’m running Ros 6.23 and the latest firmware also.
