Bridge hosts
In Mikrotik 2.9.46 hosts list in bridge change on three seconds local and some other MAC address disappear and after another tree seconds go back. I have one site with 2.9.46 and now upgrade other for 2.9.45 don’t affected to 2.9.46 and other site something.
Can someone how use bridge on 2.9.46 open bridge hosts and check this ?
Bridge is working normally.
Best regards.
We noticed that bridge on 2.9.46 is working while in a strange behavior. When you look at the hosts tab, you will see every 2 seconds all your MACs gone, including the local ones. Besides, traffic still working with eventual ICMP failures/starved connections. This is a urgent issue on ROS bridge feature. Even working, there is a problem messing arround for sure. We wont use 2.9.46 bridges anymore til a new release fixing that. Thx
