Hello
I have set up 2 bridges with HW offload on my RB3011 with 4 & 5 interface member.
Eth1 is the WAN interface
Eth 2-5 are members of Bridge-Switch1
Eth 6-10 are members of Bridge-Switch2
I use also the switch feature to manage VLAN/trunk, etc…
Everything is working as expected (Full speed with low CPU).
When I create the bridge, I have setted the admin-mac lower to the lowest MAC of the members (not sure if it is ok to do that):
My problem is when I enable or disable an inteface of the the bridge, it is not answering at all and I must disable ans re-enable it to be accessible.
What am I doing wrong ?
Thank you for your help
Ross
Here is my config:
/interface ethernet pr
Flags: X - disabled, R - running, S - slave
# NAME MTU MAC-ADDRESS ARP SWITCH
0 R ether1 1500 0A:AC:EE:11:D0:F3 enabled switch1
1 RS ether2 1500 0A:AC:EE:11:D0:F4 enabled switch1
2 RS ether3 1500 0A:AC:EE:11:D0:F5 enabled switch1
3 RS ether4 1500 0A:AC:EE:11:D0:F6 enabled switch1
4 RS ether5 1500 0A:AC:EE:11:D0:F7 enabled switch1
5 RS ether6 1500 0A:AC:EE:11:D0:F9 enabled switch2
6 XS ether7 1500 0A:AC:EE:11:D0:FA enabled switch2
7 XS ether8 1500 0A:AC:EE:11:D0:FB enabled switch2
8 XS ether9 1500 0A:AC:EE:11:D0:FC enabled switch2
9 RS ether10 1500 0A:AC:EE:11:D0:FD enabled switch2
10 sfp1 1500 0A:AC:EE:11:D0:F8 enabled
add admin-mac=0A:AC:EE:11:D0:01 auto-mac=no fast-forward=no name=Bridge-Switch1
add admin-mac=0A:AC:EE:11:D0:02 auto-mac=no fast-forward=no name=Bridge-Switch2
add bridge=Bridge-Switch1 interface=ether2
add bridge=Bridge-Switch1 interface=ether3
add bridge=Bridge-Switch1 interface=ether4
add bridge=Bridge-Switch1 interface=ether5
add bridge=Bridge-Switch2 interface=ether6
add bridge=Bridge-Switch2 interface=ether7
add bridge=Bridge-Switch2 interface=ether8
add bridge=Bridge-Switch2 interface=ether9
add bridge=Bridge-Switch2 interface=ether10
/interface bridge pr
0 R name="Bridge-Switch1" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=0A:AC:EE:11:D0:01 protocol-mode=rstp fast-forward=no igmp-snooping=no auto-mac=no
admin-mac=0A:AC:EE:11:D0:01 ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
1 R name="Bridge-Switch2" mtu=auto actual-mtu=1500 l2mtu=1598 arp=enabled arp-timeout=auto mac-address=0A:AC:EE:11:D0:02 protocol-mode=rstp fast-forward=no igmp-snooping=no auto-mac=no
admin-mac=0A:AC:EE:11:D0:02 ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
[admin@Flying-RB3011] >
