Bridge ip and reach local IPs on other ports
Have bridge with all interfaces as member - with one public IP and one private ip on the same bridge-interface (and only on bridge).
From one port - and only one sfp 10Gbps port - I can’t ping the local private ip addresses on same switch.
I can ping the other way, from Mikrotik and out that port. Just not the other way (except the bridge-IP, that works). I have no clue on what’s wrong. I do have a normal switch in that port, but it is a dumb switch. And I can ping things from inside the mikrotik network and to equipment with same local private ip-range. The switch has no firewall support, no vlans is setup - nothing.
I have removed all nat-rules and allow-all on that local IP-range in case it is beeing filtered.
The switch connected to this port do show mac-addresses from the devices on the Mikrotik-side.
