Hi, I am currently struggling with the connection between my two bridges, I have purchased Mikrotik SXTSQ 5AC bridges, i want to connect them about a 700m from each other.
At the moment they are connected with each other, but i don’t have access to the network.
My setup -
Home Router to First Device
Second device to the new router.
On the new router i don’t have internet connection.
Please help me on the setup, maybe i have messed up. Appologies maybe as i haven’t worked with these Winbox settings before.
First Device Setting export
jan/07/1970 00:20:39 by RouterOS 6.48.6
software id = XZQR-448F
model = RBSXTsqG-5acD
serial number = HD508C8KDWQ
add name=bridge1
set [ find default-name=ether1 ] rx-flow-control=auto tx-flow-control=auto
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee
country=latvia disabled=no frequency=auto mode=bridge ssid=PTP
wireless-protocol=802.11
/interface wireless nstreme
set wlan1 framer-policy=dynamic-size
add name=WAN
add name=LAN
set [ find default=yes ] supplicant-identity=MikroTik wpa-pre-shared-key=
arnolds5 wpa2-pre-shared-key=arnolds5
add bridge=bridge1 interface=wlan1
add interface=ether1 list=WAN
add interface=wlan1 list=LAN
/interface wireless access-list
add mac-address=18:FD:74:AA:00:BC
add address=192.168.88.30 interface=bridge1 network=192.168.88.30
add address=192.168.88.26 interface=wlan1 network=192.168.88.1
/ip dhcp-client
add interface=bridge1
set servers=192.168.0.20
add disabled=yes distance=1 gateway=192.168.88.0
/system identity
set name=RouterOS
Second Device Export
jan/02/1970 15:23:57 by RouterOS 6.48.6
software id = CEHC-JRSQ
serial number = HD508F6W4YY
add name=bridge1
/interface wireless
country=latvia disabled=no mode=station-bridge ssid=PTP
add name=WAN
add name=LAN
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
add address=192.168.88.10 interface=bridge1 network=192.168.88.1
add address=192.168.88.12 interface=wlan1 network=192.168.88.1
set servers=192.168.0.1
/ip dns static
add address=192.168.0.15 name=Internet
/system identity
set name=RouterOS
They are connected both.
Maybe i have missed something?
At first look, this line /ip address add address=192.168.88.30 interface=bridge1 network=192.168.88.30 seems NOT correct to me (maybe, it should be network=192.168.88.1 according to the rest of config?). Also, it might be better with network=192.168.88.0 as the main router has 192.168.88.1 (?), I assume.
Do I understand that you want this kind of network: Main Router ← cable → AP1 ← 700m wireless → AP2 ← → Some endpoints ?
If so, I would expect something like: 192.168.88.1 ← cable → 192.168.88.11 ← 700m wireless → 192.168.88.12 ← → 192.168.88.100-DHCP… with network 192.168.88.0…
Maybe, you should try to draw a complete network configuration on paper first and then recreate that using Winbox - personally, it helps me a lot when struggling with TiKs config.
For the main router details
IPv4 adress - 192.168.88.19
IPv4 DNS Server - 192.168.88.1 (Unencrypted)
To the additional router at the end i want to add the security cameras, but those can be added to the Wifi connection, but as i have no internet on that side, at the moment it is impossible.
Address seting should also include subnet mask, network addresses should be also set to proper values (or left out and ROS will assign correct value automatically) i.e.
For the first device i have update the settings.
Please see the following, don’t understand those questions about route and DNS, tried to add the route and DNS as well.
jan/07/1970 05:31:07 by RouterOS 6.48.6
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee country=latvia disabled=no frequency=auto mode=bridge ssid=PTP wireless-protocol=802.11
add name=WAN
add name=LAN
set [ find default=yes ] supplicant-identity=MikroTik wpa-pre-shared-key=arnolds5 wpa2-pre-shared-key=arnolds5
add address=192.168.88.30/24 interface=bridge1 network=192.168.88.0
add address=192.168.88.26/24 interface=wlan1 network=192.168.88.0
/ip dhcp-client
add disabled=no interface=bridge1
add distance=1 dst-address=192.168.88.1/32 gateway=ether1,bridge1,wlan1
/system identity
set name=RouterOS
As the device is acting as bridge, not a router, you only need a single IP address which should be applied to the bridge, not bridge ports. That gateway setting is complety incorrect. Changes would be along this lines of:
add name=WAN
add name=LAN
/ip dhcp-client
set servers=192.168.0.20<Your_DNS_server_IP>
add distance=1 gateway=<Your_gateway_IP> # this is your main router, not the other bridge device
They are no longer showing on the list, when i try to connect with cable and winbox, the mac adresses are not showing up. And now even the reset button is not working somehow, can’t get the factory configuration.
Tried Again, with no luck. Please help guys, I don’t know if i have setup something incorrectly or what?
When trying to connect station bridge to my Router, i have no internet connection.
Here are my settings, can you tell me what is wrong?
I did this with the quick set tool and as well took off all configs, so no defaults are there, both are giving signals. Bridge
jan/02/1970 02:04:20 by RouterOS 6.48.6
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40/80mhz-eCee country=latvia disabled=no frequency=auto mode=bridge ssid="PTP Connect " wireless-protocol=802.11
add name=WAN
add name=LAN
/ip hotspot profile
add address=192.168.88.1/24 interface=wlan1 network=192.168.88.0
add address=192.168.1.100/24 interface=wlan1 network=192.168.1.0
set servers=8.8.8.8,4.2.2.2
add distance=1 gateway=192.168.1.254
/system identity
set name=RouterOS
Station Bridge
jan/02/1970 00:47:12 by RouterOS 6.48.6
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40/80mhz-Ceee country=latvia disabled=no mode=station-bridge ssid="PTP Connect " wireless-protocol=nv2-nstreme-802.11
add name=WAN
add name=LAN
/ip hotspot profile
add address=192.168.1.101/24 interface=ether1 network=192.168.1.0
set servers=4.2.2.2,8.8.8.8
/system identity
set name=RouterOS
Sorry, i dont get it, if the channel has been selected automatically when i connect station bridge to the bridge device, it selects frequency and channels.
Well, I may be wrong, I’m not running MT devices in station modes (well, I have a pair but I’m not going to experiment), but AFAIK frequency selection is distinctive from channel layout selection - on AP, there are two properties (frequency and channel-width). Channel-width property is kind of backwards-compatible in sense that if the other end doesn’t support maximum width, then the link uses subset of channels (narrower bandwidth) supported by both AP and station. E.g. if AP is set to 20/40/80mhz-eCee and station only supports 20/40mhz (no channel layout forced), then that particular connection will work over eCee part (because the lower 40MHz make legal 20+20 channel … unless you’re manually setting things in non-standard way). But if station forces channel layout Ce, then the common denominator is only single 20MHz eCee channel. Another explanation is this: value of property frequency is center frequency of Control channel … and actually used frequency band is then limited to overlap range of AP and station channel layouts around the control channel.
So on station it’s best to let autoselection of channel layout (the same way as it’s best not to fix frequency … if AP changes frequency for any reason, station wouldn’t be able to follow).
No, you should move IP addresses (the ones you already have) from individual bridge ports to bridge interface.
I didnt had the issue with the bridge setup.
Issue was with the router that i was using for the internet connection. The ports werent working when changed the cable to different router it works.
