Bridge L2 VLan 10 = Router L3 Gateway
Bridge configuration
Created Core-Bridge-02
Assigned ports ether3 - 7 to Core-Bridge-02
Created Vlan 10 and assigned to Core-Brodge-02
Now ports ether3 through 7 are assigned to Vlan 10 using Core-Bridge-02
If I need the devices in vlan 10 to use this router as their gateway, Is the next step to create a Vlan 10 in Interfaces and assign an L3 IP address to this interface?
Essentially the router Vlan 10 is equivalent to a Cisco SVI logical L3 interface or have I messed it completely? Yikeeeessss.
Frank
Found this url the explains inter-vlan routing on a MikroTik router.
https://systemzone.net/mikrotik-vlan-routing-configuration-with-manageable-switch/
Frank
