Hi!
I have two questions for technical support.
I try to clone configuration to 4 my mikrotik grooves, - all of them had to work in bridge-mode between LAN and Wireless interfaces with the little difference in the settings. And I have a problem, which I want to share:
When I cloning configuration from one to 3 other grooves - MAC-adress for the bridge-interface - it’s cloning too! I could not think about it, and was surprised, when looked in the ARP-table in my router.
I could not find the documentation on this issue, - this is a bug or feature? -
I have a RouterBOARD RB751G, and if I connect to PPTP-server over internet, and use PPTP-client in router, when I drop session - I can’t use this connection on my PC (which connect to this router, in local network, and connected to internet over masquarade). And conversely, when I drop PPTP-session on my PC - I can’t connect to the same PPTP-server from router’s client. This bug observed from RouterOS version 5.16. Need to reboot the RouterBOARD for established new PPTP session.
Please, fix it in the new versions of RouterOS.
Thanks!
