Hello all,
New to Mikrotik I’m having trouble to set up management IP on my swith using bridge, switch CRS326-24G-2S+ RouterOS 6.48.6.
Bridge, acces port, trunk port, vlan are working fine but no way to have a management IP working on the bridge.
It is probably obvious, probably just in front of my nose but I’m stuck on it, help would be apreciated.
My goal: to be able to reach (manage) the switch with IP 192.168.77.250 on VLAN 77. Currently it does not work.
As a workaround I use port 24 which is not in the bridge to manage the switch with IP 192.168.69.250, and this is not what I want.
Here is the config:
# jan/16/1970 07:08:40 by RouterOS 6.48.6
# software id = 6NLR-3YB0
# model = CRS326-24G-2S+
# serial number = xxxxxxxxxx
add admin-mac=xxxxxxxxxx auto-mac=no name=bridge1 vlan-filtering=yes
set [ find default-name=ether1 ] name=01_T_bond_forti
set [ find default-name=ether2 ] name=02_T_bond_forti
set [ find default-name=ether3 ] name=03_A_TCapsule
set [ find default-name=ether4 ] name=04_A_forti_69
set [ find default-name=ether5 ] name=05_A_69
set [ find default-name=ether6 ] name=06_T_forti_200
set [ find default-name=ether7 ] name=07_T_bond_S3
set [ find default-name=ether8 ] name=08_T_bond_S3
set [ find default-name=ether9 ] name=09_A_syno_77
set [ find default-name=ether11 ] name=11_A_syno_300
set [ find default-name=ether13 ] name=13_A_apc_77
set [ find default-name=ether24 ] name=24_A_MGT_69
/interface vlan
add interface=bridge1 name=INFRA_77 vlan-id=77
/interface bonding
add name=bond_S3 slaves=07_T_bond_S3,08_T_bond_S3 transmit-hash-policy=layer-2-and-3
add mode=802.3ad name=bond_forti slaves=01_T_bond_forti,02_T_bond_forti transmit-hash-policy=layer-2-and-3
add name=WAN
add name=LAN
add bridge=bridge1 interface=bond_forti
add bridge=bridge1 interface=bond_S3
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=03_A_TCapsule pvid=69
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=04_A_forti_69 pvid=69
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=05_A_69 pvid=69
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=06_T_forti_200
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=09_A_syno_77 pvid=77
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=11_A_syno_300 pvid=300
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged interface=13_A_apc_77 pvid=77
add bridge=bridge1 interface=INFRA_77
/interface bridge vlan
add bridge=bridge1 tagged=bond_S3 untagged=03_A_TCapsule,04_A_forti_69,24_A_MGT_69 vlan-ids=69
add bridge=bridge1 tagged=bond_forti,bond_S3 vlan-ids=22
add bridge=bridge1 tagged=bond_forti,bond_S3,bridge1,01_T_bond_forti,INFRA_77 untagged=09_A_syno_77,13_A_apc_77 vlan-ids=77
add bridge=bridge1 tagged=bond_S3,06_T_forti_200 vlan-ids=200
add interface=02_T_bond_forti list=LAN
add interface=03_A_TCapsule list=LAN
add interface=04_A_forti_69 list=LAN
add interface=05_A_69 list=LAN
add interface=06_T_forti_200 list=LAN
add interface=07_T_bond_S3 list=LAN
add interface=08_T_bond_S3 list=LAN
add interface=09_A_syno_77 list=LAN
add interface=ether10 list=LAN
add interface=11_A_syno_300 list=LAN
add interface=ether12 list=LAN
add interface=13_A_apc_77 list=LAN
add interface=ether14 list=LAN
add interface=ether15 list=LAN
add interface=ether16 list=LAN
add interface=ether17 list=LAN
add interface=ether18 list=LAN
add interface=ether19 list=LAN
add interface=ether20 list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface=ether23 list=LAN
add interface=24_A_MGT_69 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=01_T_bond_forti list=LAN
add interface=INFRA_77 list=LAN
add address=192.168.69.250/23 interface=24_A_MGT_69 network=192.168.68.0
add address=192.168.77.250 interface=INFRA_77 network=192.168.77.250
set servers=192.168.45.5
add distance=1 gateway=INFRA_77
/system identity
set name=s0.srv.home
/system ntp client
set enabled=yes
/system routerboard settings
set boot-os=router-os enter-setup-on=delete-key
/system routerboard reset-button
set enabled=yes hold-time=0s..10s
/system swos
set address-acquisition-mode=static allow-from-ports=\
p1,p2,p3,p4,p5,p6,p7,p8,p9,p10,p11,p12,p13,p14,p15,p16,p17,p18,p19,p20,p21,p22,p23,p24,p25,p26 identity=s0.srv.home \
static-ip-address=192.168.77.250
/tool romon
set enabled=yes
Thanks for your help.
