Bridge & Mangle
I have this problem:
For VoIP priority reasons, I need to mark the packets that flow in a bridge.
In particular I have to mark the packets with a particular DSCP.
I’ve make this setup:
In the bridge:
use-ip-firewall = yes
In the ip firewall:
0 chain=forward action=mark-connection new-connection-mark=VoIP
passthrough=no dscp=40
1 chain=forward action=mark-packet new-packet-mark=VoIP pck passthrough=no
But doesn’t function…
If I set the Bridge Filters like this:
0 chain=forward out-bridge=bridge2 action=mark-packet new-packet-mark=Users
I’m able to mark (with Users) the packet that flow the bridge, but I’m not able to use that for my purposes…
Please anyone can help me?
Thanks.
Do you want to mark packet that are coming with DSCP=40
or you want to assign DSCP=40 to specific packets ?
Your mangle rule is working for the first option, it’s marking packets on router, which enter with DSCP=40.
To set DSCP=40 use action=change-dscp new-dscp.
Hi Sergejs,
thanks for your replay.
I want mark packet that flow in the bridge with DSCP=40 to put their in a queue with high priority.
Do you have DSCP on this flow, before it’s entering the router ?
Yes,
but for verify the configuration I’ve tried also to mark all packet that flow the bridge (without DSCP=40) , but the problem is that the counter is always 0…is like the rule doesn’t see any packets flowing the bridge…but I’m sure to have traffic.
Please any suggestion? I need very much…thanks…
It’s impossible that nobody has tried to do shaping with bridge using DSCP…c’mon!!! :frowning:
Have you tried using prerouting chain ? Forward chain in firewall is habitualy used for routed packets.
For the bridge and firewall configuration,
set ‘interface bridge settings set use-ip-firewall=yes’.
to make sure that bridged packets are going through the firewall.
