Hi guys! I have a simple question! how to masquerade one bridge to another? It is posible? One bridge have internet, and i just need forward this internet to another bridge.
More detailed:
Router Mikrotik CRS125-24G-1S-2HnD-IN (Router OS 6.41, CapsMan activated) + 4 cAP (Router OS 6.41 on each).
eth1-eth8 in “bridge-local” and all cAP’s turned on in arbitrary port from 1 to 8. If i plug in my corp local (10.10.10.) to any eth1-eth8 port - i have my corporative network on each mobile devises, like i need! Its called - “corp-wifi”. No question on that stage, BUT i needed also “guest-wifi”, no problem (I thought) just create “guest-pool”, make a DHCP-server to “guest-pool”, make “guest” conf on CapsMan and bind this “guest-pool” to “guest-conf” - works like a charm! My guests receive isolated IP from “guest-pool” (192.168.10.) but … without internet
So how to throw internet from “bridge-local”(work net with internet) to “guest-bridge” (virtual Wi-Fi on cAPs)?
Thank you, and sorry for my bad english, im from USSR
Did you assign an address within the guest range to your guest bridge? Like 192.168.10.1?
Does your DHCP push this address as default gateway to your your clients?
Did you add a srcnat/masquerade rule for guests? Like
Yes i did. I make test net in my home, so let imagine my work net is 192.168.88.0/24, and guest pool is 10.10.10.0/24. Then in “IP - adresses”: Address: 10.10.10.1/24, Network: 10.10.10.0, Interface: bridge-guest.
Do I see it correctly that your router is not really the router for the network?
So your bridge-local is currently your WAN interface?
Do you have a default route configured?
Yes, you right! I already have configured network on my work, so i need just extension for my network by wifi. So my Mikrotik CS125 not a router in that case, so i simple make eth1 - eth8 as local-bridge, and my colleagues get IP’s and have access from mobile devices to work resources.
You are see clearly right! My WAN and all cAPs connected to “bridge-local” (eth1-eth8).
Firewall NAT rules only work on routed traffic. So if your Mikrotik itself has no default route, the phone sends packets towards the Mikrotik (because the phone gets Mikrotik’s IP address in its subnet as a gateway), but the Mikrotik doesn’t know where to forward that traffic, and as it does not forward it, it doesn’t do src-nat either.
(note regarding vocabulary - “gray” and “white” addresses are not widely understood among English-speaking audience, “public” and “private” is used to distinguish the address ranges).
Thank you for answer! Sorry about “color” of adresses, I did not mean to offend anyone.
Can you give me advice please, which exactly “default route” i must write in my “IP - Routes” to have internet in my “bridge-guest”? I’m totally lost
My remark had nothing to do with political correctness, only with readability. I come into contact with russian-speaking network specialists but many others don’t.
Can you use command line and publish the results of the following commands?
# feb/02/2018 21:14:05 by RouterOS 6.41
# software id = RN4X-NAWF
# model = CRS125-24G-1S-2HnD
# serial number = 49C602EE2CCD
add name=guest-pool ranges=10.10.10.100-10.10.10.200
add address-pool=guest-pool disabled=no interface=bridge-guest lease-time=59m name=dhcp1
add address=192.168.88.90/24 interface=bridge-local network=192.168.88.0
add address=10.10.10.1/24 interface=bridge-guest network=10.10.10.0
add address=10.10.10.0/24 dns-server=8.8.8.8 domain=steel.guest gateway=10.10.10.1 netmask=24
add action=src-nat chain=srcnat disabled=yes dst-address=0.0.0.0/0 out-interface=bridge-local src-address=10.10.10.0/24 to-addresses=192.168.88.90
/ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADC 10.10.10.0/24 10.10.10.1 bridge-guest 0
1 ADC 192.168.88.0/24 192.168.88.90 bridge-local 0
xopowo, that means that @cdiedrich’s guess was correct. The WiFi clients in the “work” network which get their IP settings from the Cisco get them via DHCP, but the Mikrotik has its own IP address from 192.168.88.0/24 configured manually rather than asking for it using DHCP, and therefore it cannot receive the default gateway address from the Cisco. So the following command should solve your issue:
/ip route add gateway=192.168.88.x
where 192.168.88.x is the address of the Cisco router on which the DHCP server is running.
Another possibility would be to attach a dhcp client to bridge-local (you can do it while the manually assigned address still exists in the configuration) and create a static reservation for the Mikrotik in Cisco’s DHCP server configuration. After that, you could remove the manually configured IP address. But in such case you’d also have to replace the src-nat action in your NAT rule by “masquerade”.
I forgot one little detail. I brought the controller from work office to my home. This way i can simulate my office situation, except that my home router Mikrotik 751 replaces Cisco. As well as in the office, my 751 gives to CS125 DHCP, so the whole situation is correct.
/ip route add gateway=192.168.88.1
ITS WORK!
Thank you so much Sindy for the invaluable help!!! I do not understand clearly this commands, but its works and i promise find out HOW its works! (especially src-nat
And last little question, is this correct prohibition rule for boths net?
It is correct in terms that it prohibits any traffic between the two networks as you most likely wanted, but
this type of limitation is usually placed to “filter” table, chains “input” (to protect the device itself) and “forward” (to protect clients from one another)
action “unreachable” causes an icmp response packet to be sent back, while action “drop” just silently drops the packet so it consumes less CPU and bandwidth
