Bridge - maximum bandwidth =- short distance
Forgive me if I’m in the wrong place but today is my first day looking at MikroTik.
Background - 1000 hosts on a 100Mb VLAN’ed network with multiple WAN links. We’re moving shortly to a building 100 metres away (currently a big hole in the ground). We will lay fibre to the new building and move equipment item by item as we are a 24/7 operation. I need a wireless backup solution for the day they cut through the fibre. What should I be looking at. I’m in the U.K.
Hi there,
Have you considered a laser link?
Will give you the 100Mbps or 1000Mbps dedicated throughput.
(to avoid ‘flames’ from a shameless commercial pitch on laser links on MT’s forum, contact me offline - also in the UK - stephen.patrick@cablefree.co.uk)
Otherwise an RF link, that would be 24Mbps half-duplex from a standard commercial product, or 44Mbps with all the latest MT stack loaded on.
RF links can go an awful lot further distance than laser links.
Stephen
with latest 2.8.16 (on 2 ghz celeron platform) we got over 50 mbit/s throughput half-duplex or 25 mbit/s full-duplex with 802.11a-turbo and (single-) nstreme on a 1.5 km link.
has to be proven by further testing, but it seems the right direction…
44Mb/s wouldn’t be enough so details of your products have been salted away until there is less of a hole, the cranes are up and I’ve a better idea of line of site.
Thanks.
Wow that is really impressive!
We are about to do tests using 1GHz VIA EPIAs, 802.11a.
Do you think our CPUs are fast enough?
  • What CPU usage did you get on 2GHz celerons?
  • What radio cards did you use?
    Stephen
i haven’t tried 1ghz CPUs. with 300 mhz throughput is about 10 mbit/s at 100 percent CPU load.
the 2 ghz CPUS had 20 to 50 percent load
Atheros AR5212 (PCI)
I’ve got two routerboards using the 100mW Atheros a/b card over a 17.8 mi. link, and am getting 10Mbps at 5.8, on 5805MHz using two 32dB PacWireless dishes. I find that Nstreme or encryption, or 5GHz-turbo just slows things down. I also find that playing with the power levels just degrades performance. The ACK setting is also on automatic.
what’s the signal strength that you see?
