Had to emergency connect 4G router to Mikrotik WAN port - ether1 (because ISP fibre connection died due to cables being cut some place else)
As the 4G Huawei router provides DHCP, it was easiest to configure in bridged mode.
But I would expect that this would automatically disable DHCP on Mikrotik ether2-master bridge (maybe wrong assumption, or maybe I did not select some settings while settings Bridged connection)
What I ended up with was some devices obtaining IP from 4G router fine, some getting nothing at all, some getting most odd like 0.0.0.2 255.0.0.0
Had to manually disable defcon DHCP server. Once done all dhcp request were dealt with by 4G router
If you didn’t disable it yourself, mikrotik won’t do it for you, that’s for sure.
On the other hand, if talking about “bridge mode”, you mean quickset, then I’m going to disappoint you: quickset is not meant to be used on the router, that has a non-default configuration. I mean at all. It can screw you configuration in an hardly predictable way (the exact situation you found yourself in).
non-default configuration I assume would be just “blank” OS with zero configuration.
Anyway, I would expect some logic build in, so user does not do something that “should not” happen.
That is what I normally expect from the gear I work with. But well…
Quickset is just a set of scripts, that apply different predefined configurations with some user-defined variables (like names, passwords, some checkbox-type options).
There is absolutely no way someone could make such script check all possible collisions with already written configuration.
So two behaviours are theoretically possible: to overwrite the whole configuration, or to overwrite only fields, that are relevant to current quickset template.
I, personally, would prefer it to go with removing the whole configuration (with a warning, of course).
But for some reason it is not the case.
So you end up with leftovers from the previous config.
While there are some warnings in help web page for quickset, there are indeed no warnings in the script itself.
I agree that a popup message or just a remark in red on the bottom of the window would be a good addition.
I should add my byline, which is ASCERBIC LLAMA. if you cannot laugh while configuring an MT router, you will die at a young age.
Hey compared with my good looks, fetid hot breath and flatulence, only perhaps Chapuka has similar physical aesthetic appeal. Sorry xvo!
