Bridge mode or DMZ ?
Hi folks,
Newbie here. Just received my Mikrotik LHG LTE6 kit.
I want to turn off the routing (place in bridge mode) and use the LTE modem only. Another wirelsss router will handle wifi / routing/DHCP etc.
Or alternatively, DMZ all packets to another wifi router.
Can’t seem to find an option to bridge mode in Webfig or a DMZ option.
I guess the LHG LTE6 kit software might be different than a Mikrotik router.
Seeking assistance. Thanks!
use winbox or ssh!
Hey satman1w.
Downloaded Winbox, better laid out than webfig, still not seeing any apparent option.
Can you provide some guidance on how to place router in bridge mode ?
thanks
Enter the bridge menu - create bridge - add interfaces that you want to be bridged…
that’s it!
Do not forget to move IP adress (if there was one on one of the interfaces) to the bridge… also if there was a DHCP server defined on one of the bridged interfaces, move it to the bridge instead…
enjoy
Hey satman1w,
I tried this and could not get it to work.
Sure i’m missing something…
Not seeing where i input to direct bridge traffic to the tplink router on lan.
Can you break this down more, or direct me to an article / solution?
thanks again
I appologise for not answering your question… I was not aware of your post..
By now you have probably find a solution?
