bridge mode with vpn
i am new to mikrotik. I would like to know is it possible to have the mikrotik cloud switches set as bridge mode and at the same time configure VPN on it?
What I would like to do is have some servers behind the mikrotik using LAN IP. In order to connect to these server, I would need to use VPN. Maybe have certain port on the switch configured for this?
But the rest of the devices will be using bridge mode with public IP.
Thanks.
Yes, you can configure a CRS to route some interfaces and bridges others. Also, you can bridge two [or more] networks with a VPN, or route between them, across a VPN.
wow..good to know it can be done with mikrotik.
Can you provide some guide on how to do this? Perhaps some available tutorial or some sort simple instructions?
Thanks.
after doing a little bit more googling, I think I have the idea on how to do this.
So basically I will need to group the ports up. Probably create another group called group-lan which is port 17-24. This group will be used for internal IP and VPN. Then I assign locate IP address into this group? Is this correct? Please comment.
Thanks.
Set ports 18-24 with a master port of 17, set port 17 to have a master port of none. This will make ports 17-24 their own L2 domain, separate from 1-16. You can then assign an IP address to port 17.
Note that the canonical way to do this with ROS would be to create a bridge with ports 17-24 in and put the IP on the bridge but things are a bit different with CRS.
