Using a 750up I want to use one connection coming into eth1 to deliver 2 public IP’s to separate customers. One will be NAT’d on eth2 while the other gets an IP directly on eth3.
Getting the communications between eth1 and eth3 is no sweat with a bridge but how or should I use Bridge NAT for the customer on eth2?
Thanks for responding Van9018
I am planning on assigning 2 publics to the device then routing one to eth2 and the other to the customer on eth3. Any special approach you would take to that setup?
No special approach. Maybe add firewall rules to prevent customers from trying to log into the Mikrotik. With default config, I think ether1 is the only one that doesn’t allow logging into the Mikrotik.
