SITE 1, private lan with range 192.168.100.0/24 - port 2,3,4 bridged in bridge called ‘PRIVATE LAN’
SITE 2, private lan with range 192.168.15.0/24 - port 2, wlan1 bridged in bridged called ‘bridge-local’
The L2TP tunnel is connected and I can succesfully ping 172.16.1.1 and 172.16.1.2 from both sites.
When I logon to the terminal of de RB on SITE 2 I can also succesfully ping devices on the PRIVATE LAN of SITE 2, but as from the moment I start a ping from a device on SITE 2 connected on the bridge-local bridge the ping fails.
On SITE2 I’ve added a route “192.168.100.0/24 with as gateway my L2TP tunnel” but without any succes.
I think you miss some routes :
On site 1: /route add dst=192.168.15.0/24 gateway=172.16.1.2
On site 2: /route add dst=192.168.100.0/24 gateway=172.16.1.1
Your “clients” behind the routers must also have those routes (if their default gateway isn’t the local mikrotik device).
Those routes already exists, clients have the RB as their default gateway.
On a client I can succesfully ping 172.16.1.1 or .2 but not the 192.168.100.0/24 network
When I do a traceroute via interface PRIVATE LAN it seems that he’s sending traffic through it’s default gateway instead of using the route I’ve devined for the 192.168.15.0 network.
I’ve made some progress, when I start a ping from a device on the 192.168.100.0/24 network to a device on the 192.168.15.0/24 network, and start a torch on the L2TP interface i see on the 100.0/24 network TX traffic and on the 15.0/24 RX traffic, but the traffic is not going back..
Export from the router on the 192.168.100.0/24 network:
[user@router] > /ip export
# jun/05/2014 20:57:30 by RouterOS 6.4
# software id = 5E5R-ZA5D
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
/ip neighbor discovery
set ETH1 comment="UPLINK "
set ETH2 comment="UPLINK FW PROTECTED"
set ETH3 comment=VIRT1
set ETH4 comment="UPLINKS FW UNPROTECTED"
set ETH9 comment="UPLINK PRIVATE LAN SW 2"
set ETH10 comment="UPLINK PRIVATE LAN SW1"
set ETH3.107 discover=no
add name=dhcp_pool1 ranges=192.168.100.100-192.168.100.110
add name=dhcp_pool2 ranges=192.168.100.110,192.168.100.120
add address-pool=dhcp_pool2 disabled=no interface="PRIVATE LAN" name=dhcp1
add address=192.168.100.254/24 interface=vrrp-PRIVATE_LAN network=192.168.100.0
add address=81.95.x.y/26 interface=Servers network=81.95.x.y
add address=185.18.x.y/32 interface=Servers network=185.18.x.y
add address=192.168.100.252/24 interface="PRIVATE LAN" network=192.168.100.0
add address=192.168.100.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.100.254
set allow-remote-requests=yes
/ip dns static
add address=8.8.8.8 name="Google 1"
add address=8.8.4.4 name=Google2
/ip firewall address-list
add address=80.190.147.92 list=0.ntp.pool.org
add chain=forward
add chain=input
add chain=output
/ip firewall mangle
add action=mark-connection chain=prerouting new-connection-mark="PRIVATE LAN" \
src-address=192.168.100.0/24
add action=mark-connection chain=prerouting dst-address=192.168.100.0/24 \
add action=masquerade chain=srcnat comment="Masquerade voor PRIVATE LAN" \
disabled=yes dst-limit=0,100,dst-address limit=0,100 src-address=\
192.168.100.0/24 to-addresses=81.95.x.y
add action=masquerade chain=srcnat dst-address=!192.168.15.0/24 src-address=\
192.168.100.0/24
add action=dst-nat chain=dstnat comment="Port Forwards" dst-address=\
81.95.x.y dst-port=21 protocol=tcp to-addresses=192.168.100.1 to-ports=\
21
/ip proxy
set max-cache-size=none parent-proxy=0.0.0.0
add distance=1 gateway=81.95.x.y
add distance=2 gateway=185.18.x.y
/ip service
set telnet disabled=yes
set api disabled=yes
/ip traffic-flow
set cache-entries=4k interfaces=ETH1
/ip traffic-flow target
add address=192.168.100.5:2055 version=5
Export from the router on the 192.168.15.0/24 network:
Firstly I agree to noib not seeing the routes.
Second, try adding these NAT rules on the two routers on top position (before your masquerade rule kicks in): #site1
add chain=srcnat dst-address=192.168.15.0/24 src-address=192.168.100.0/24
#site2
add chain=srcnat dst-address=192.168.100.0/24 src-address=192.168.15.0/24This will prevent the routers from sending the VPN traffic through their default gateways.
Following routes are active on Site 1:
[admin@router] > /ip route print
DST-ADDRESS PREF-SRC GATEWAY DIST
0 A S 0.0.0.0/0 192.168.0.1
1 ADC 172.16.1.1/32 172.16.1.2 VPN-HOME-DCO
2 ADC 192.168.0.0/24 192.168.0.200 ETH1
3 ADC 192.168.15.0/24 192.168.15.1 bridge-local
4 A S 192.168.100.0/24 172.16.1.1on site 2:
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 81.95.x.y 1
2 ADC 81.95.x.y/26 81.95.x.y Servers 0
3 ADC 172.16.1.2/32 172.16.1.1 <l2tp-VPN-DCO-H... 0
4 ADC 185.18.x.y/32 185.18.x.y Servers 0
5 A S 192.168.15.0/24 172.16.1.2 1
6 ADC 192.168.100.0/24 192.168.100.252 PRIVATE LAN 0
vrrp-PRIVATE_LAN
7 ADC 192.168.100.107/32 81.95.x.y 0I've added the 2 nat rules as described but isn't working.. /helpless !
