Bridge or Routing which one is better.
Here we have 3 radios XR2, 3 sector anteenas to serve 100 clients and we want this setup
Ethernet<>… Mikrotik AP RADIO Wlan1, Wlan2, Wlan3…<>Client CPE
10.10.0.0…10.10.0.0
How can i achieve this thing…i know i can do with bridge…but i heard by bridging 3wlan together will eats up a lot of bandwidth unnecessarily..Is there any other way to do this…I dont know how to do this with routing
Help me pls
If you need all you wireless interfaces on same IP subnet you have to use bridging. Otherwise it is best to use routing.
We Have a server at our side with billing software installed and working fine…as i have server i dont want Nat and dhcp on mikrotik router.
Here is our network diagram…As mikrotik guy suggested Ur 2 XR2 600Mw radio he also suggested us to apart the sector antenna 7 ft from each other otherwise you will face self interference. is this true?
At client side he recommended Nano Loco 2.
Ethernet<>… Mikrotik AP RADIO Wlan1, Wlan2…<>Client CPE
10.10.0.0…10.10.0.0
I heard by bridging 2wlan together will eats up a lot of bandwidth unnecessarily..Is there any other way to do this…I dont know how to do this with routing.
Please Help me on this matter.
  1. XR2 600mw radios would be effective in a noisy area.
  2. Is there any need to separate sector antenna 7–10 feet from each other.
  3. Any other way except bridging.
