Bridge Pihole, DNS Difficulties
Howdie all, fairly new, and there might be a simple answer but I certainly haven’t been able to find one, so this but here we are. I have a MikroTik as the entry point to my network. This is a family router, so the port I use is bridged, with a separate Network and DHCP pool (They’re on 192.168.88.0/24 while I’m on 192.168.6.0/24). I have both mine and their bridges on the interface list with the WAN. I have a server running on my network, from which I want to run a PiHole. The problem is DNS. I’ve currently got my network being routed to a Pihole container on my server, Which is actually sort of working, at least some ads are being blocked, but definitely far from all. I’m thinking that it must be using the default configuration DNS by me putting it in the interface list, but thats just speculation as like I said I’m new, and furthermore I’m not sure how I’d go about sorting that. Any ideas?
For those who ask:
 #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
 0  R  ether1                              ether            1500  1598       9214 08:55:31:9B:0A:C6
 1  RS ether2                              ether            1500  1598       9214 08:55:31:9B:0A:C7
 2  RS ether3                              ether            1500  1598       9214 08:55:31:9B:0A:C8
 3  RS ether4                              ether            1500  1598       9214 08:55:31:9B:0A:C9
 4  RS ;;; ORA Network Devices
       ether5                              ether            1500  1598       9214 08:55:31:9B:0A:CA
 5  RS wlan1                               wlan             1500  1600       2290 08:55:31:9B:0A:CB
 6   S wlan2                               wlan             1500  1600       2290 08:55:31:9B:0A:CC
 7  R  ;;; defconf
       bridge                              bridge           1500  1598            08:55:31:9B:0A:C7
 8  R  ;;; ORA Bridge
       bridge2                             bridge           1500  1598            08:55:31:9B:0A:CA
[admin@MikroTik] /interface> cd ..
bad command name cd (line 1 column 1)
[admin@MikroTik] /interface> ..
[admin@MikroTik] > export
# mar/25/2021 20:45:01 by RouterOS 6.48.1
# software id = CDLH-8UJV
# model = RBD52G-5HacD2HnD
# serial number = CDFD0D2B03DF
add admin-mac=08:55:31:9B:0A:C7 auto-mac=no comment=defconf name=bridge
add admin-mac=08:55:31:9B:0A:CA auto-mac=no comment="ORA Bridge" name=bridge2
set [ find default-name=ether5 ] comment="ORA Network Devices"
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="united kingdom" disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-2GHz wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country="united kingdom" disabled=no distance=indoors frequency=auto installation=indoor mode=\
    ap-bridge ssid=MikroTik-5Ghz wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=* wpa2-pre-shared-key=*
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=ORAPool ranges=192.168.6.10-192.168.6.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=ORAPool disabled=no interface=bridge2 name=ORA-dhcp
add bridge=bridge2 comment=defconf interface=ether5
add bridge=bridge comment=defconf interface=wlan2
add independent-learning=no ports=ether1 switch=switch1 vlan-id=200
add interface=bridge2 list=LAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.6.1/24 interface=bridge2 network=192.168.6.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
add address=192.168.6.0/24 comment="ORA Network" dns-server=192.168.6.21 gateway=192.168.6.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Europe/London
/tool mac-server
/tool mac-server mac-winbox
Not that its much outside the default I imagine.
Why not share you current DHCP and DNS configuration, assuming they’re configured on the Mikrotik ..
/ip dns export
/ip dhcp export
Essentially you have two ways of doing his, you could get your DHCP to dish out the Pihole’s IP address as the DNS for all your clients. Or you could configure the Mikrotik as a caching DNS server (which has some benefits) but configured to use the Pihole as it’s source.
