Hi all. I have a CRS305-1G-4S+ running 6.45.7 - with the following design.
| LAN
| 192.168.13.205/24|--------|sfp1-viewer ether1-config| | |
|C1 | |PVID 13 | | |
| CRS305 | | S1 |
| |--------|sfp2-acso1 PVID 1 | | |
| 192.168.14.x/24| |PVID 14 T 13+14 | | /VLAN14 |
|C2 | /sfp3-acso2 sfp4-mvc -------|eth0--VLAN13 |
| 192.168.14.x/24-
|C3 |
Following https://wiki.mikrotik.com/wiki/Manual:Basic_VLAN_switching I’ve set up:
[admin@testrig-mt] > /interface bridge print
0 R name="acs-bridge" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=74:4D:28:64:F7:AD protocol-mode=none fast-forward=no
igmp-snooping=yes multicast-router=temporary-query multicast-querier=no startup-query-count=2 last-member-query-count=2 last-member-interval=1s
membership-interval=4m20s querier-interval=4m15s query-interval=2m5s query-response-interval=10s startup-query-interval=31s250ms igmp-version=2
auto-mac=yes ageing-time=5m vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-all ingress-filtering=no dhcp-snooping=no
I’m connected via ether1 for mgmt, so no mgmt VLAN needed.
[admin@testrig-mt] > /interface bridge port print detail
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
0 H interface=sfp2-acso1 bridge=acs-bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto
point-to-point=auto learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no
restricted-tcn=no pvid=14 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes
unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no
multicast-router=temporary-query fast-leave=no
1 I H interface=sfp3-acso2 bridge=acs-bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=yes
point-to-point=no learn=auto horizon=none hw=yes auto-isolate=no restricted-role=no
2 H interface=sfp4-mvc bridge=acs-bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=yes
restricted-tcn=no pvid=1 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes
3 I H interface=sfp1-viewer bridge=acs-bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto
restricted-tcn=no pvid=13 frame-types=admit-all ingress-filtering=no unknown-unicast-flood=yes
And the VLAN config:
[admin@testrig-mt] > /interface bridge vlan print detail
Flags: X - disabled, D - dynamic
0 bridge=acs-bridge vlan-ids=13 tagged=sfp4-mvc untagged=sfp1-viewer current-tagged=sfp4-mvc current-untagged=""
1 bridge=acs-bridge vlan-ids=14 tagged=sfp4-mvc untagged=sfp2-acso1,sfp3-acso2 current-tagged=sfp4-mvc current-untagged=sfp2-acso1
2 D bridge=acs-bridge vlan-ids=1 tagged="" untagged="" current-tagged="" current-untagged=acs-bridge,sfp4-mvc
No filtering or any other magic enabled. It should be a simple switch with two VLANs. v14 on two ports, v13 on another; both of them trunked on the fourth.
v14 works fine. I can connect a machine to sfp2 or sfp3, get a DHCP address form S1 and forward traffic. Not so the sfp1-viewer port. For some reason, this port is stuck in ‘inactive’ even though the remote side link is up (auto-negotiates at 1Gb/FD). The monitor shows:
[admin@testrig-mt] > /interface bridge port monitor 3
interface: sfp1-viewer
status: in-bridge
port-number: 4
role: disabled-port
edge-port: no
edge-port-discovery: yes
point-to-point-port: yes
external-fdb: no
sending-rstp: yes
learning: no
forwarding: no
multicast-router: no
hw-offload-group: switch1
I’ve disabled STP on the bridge, but the port is ‘sending-rstp’. Not sure if that’s relevant.
I’ve swapped SFPs, cables and switch ports and the problem seems to follow VLAN 13. Is there something I’m missing?
Cheers,
Terry
