Bridge->Ports, Drivers (problem)
Hi…
I use Lucent Orinoco Silver PCMCIA cards with PCI adapters. Wireless connection between two routers works just fine, but it can’t be seen in ‘Drivers’ or ‘Bridge->Ports’ section? Why is that?
Tnx
What version of MT are you using?
2.9.6
Try to upgrade to 2.9.12 and see if that happen
Regards
Same thing :frowning:
Do you see it on interfaces?
[admin@MikroTik] > interface print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R ether1 ether 0 0 1500
1 R wavelan1 wavelan 0 0 1500
[admin@MikroTik] >
[admin@MikroTik] > driver print
Flags: I - invalid, D - dynamic
DRIVER IRQ IO MEMORY ISDN-PROTOCOL
0 D 3com 3c59x PCI
[admin@MikroTik] >
...also, when trying to make a bridge, wavelan1 is not offered as interface, only ether1!
Maybe I sould say that the same problem occurred on both roters. One Orinoco Silver is connected over ISA adapter, and the other over PCI adapter.
You should send a e-mail to support@mikrotik.com with support.rif they may have the answer to your problem
Regards
