From reading https://wiki.mikrotik.com/wiki/Manual:Spanning_Tree_Protocol
it reads “…RouterOS is capable of running bridge interfaces with (R/M)STP support in order to create loop-free and Layer2 redundant environment. It is always recommended to manually set up each bridge’s priority, port priority and port path cost to ensure proper Layer2 functionality at all times. Leaving STP related values to defaults are acceptable for a network that consists of 1 to 2 bridges running with (R/M)STP enabled, but it is highly recommended to manually set these values for larger networks. …”
I would ask what is the recommended manual bridge priority when there is no failover route on the network
(1) AP - Two bridges OSPF Loopback and PPPoE
(2) RB960POE with 5 bridges OSPF loopback and 4 for interface ether1,2 - Ether1,3 - Ether1,4 - Ether1-5
(3) PTP 5 bridges OSPF loopback + 4
