Hi guys. Please help me resolve this problem.
I have mikrotik CCR 1036 4g 12s
Hi
Your current config is:
1 firewall: blocking communication between 172 & 10
2 routing: blocking routing between 172 & 10
But want them to be able to communicate, right ?
please help me open this firewall and nat rule
Start by removing all those listed rules: 2 firewall rules and 4 router rules.
“Default config” should be enough then. If not, please list your config:
/export hide-sensitive
okey
it seems your IP ROUTE table is empty ?
I don’t see anything out of ordinary:
No firewall rules (except nat masq) => all is ACCEPTed
routing table no non-default entries: so should include connected routes for each network + default gateway from dhcp-client
=> please verify that?
So, should be working as is.
Few other remarks to look into later, but non-blocking:
The inter-network (172 ↔ 10) communication should be working as is. How did you verify that it isn’t?
not working
ok thanks for answering
What have you tried? Could you explain how “it is not working”?
I’m asking as from pure router configuration, the network level communication is allowed.
client run: \ftp share folder not opening
Few things to check:
